wikilivia
I currently work with the 2015 version of autocad architecture and I have several problems including the fact, in which I came across for the umpteenth time now, that when I try to apply a material to the glass part of the window object, it does not apply. I don't know why, it has "earned" the material I applied to the frame and other parts but not for the glass part. I applied everything from edit object view, then since it does not display I tried modifying also in the window style, but nothing. and the problem arises all the time... until now I have solved going to recover windows from files generated with previous version of the same program, but I would like to succeed in finding the solution and especially understand if it is me wrong or if it is a program error.
Thanks for the help,
Livia
Livia
