autocad does not print font fillings, pictures, retini, etc.
  • Thread starter Thread starter serioires
serioires
Hello everyone!
tomorrow morning I have to deliver an elaborate and obviously I'm in trouble.
in practice, both in pdf printing and in printer printing, in the cartiglio and in the table are "empted" all characters (arial, nothing that).
At the same time the coloured retinaes are removed from various parts of the table.. .
is not a question of unprintable layers. is not a matter of fonts (because it also empties the retini). .
Never happened that.
What can I do?
thank you all, hello...
to facilitate the definition of "empty fillings" allego photo.. .This character is a simple bold... Why do you leave me like this? ! ?
do so also with the retinals (e.g. the sampling of a wall), etc...
are the variables that influence the behaviors you describe.
I don't think of anything else, in the absence of other straights the quickest thing is to try a autocad repair.
from the control panel:
windows xp -> installation applications -> select your version -> change\remove -> repair or reinstall
windows 7 -> uninstall a program -> select your version -> repair or reinstall
p.s.: if you can attach a dwg with some object that presents the problem.
check that on the print settings under the "Shadow Shading option" entry on the "Shadow print" field is set "as displayed" and on the model space or layout/fines display style is set to "wireframe2d"
Bye and let us know.
ps. I hope you have not already embarked on the road to autocad restoration, the problem so you do not solve it probably, because the information of views is saved in the dwg.
