Shape
Does anyone know if there may be problems installing autocad lt2000 on the new homecoming microsoft windoes 7?
windows 7 is supported in autocad 2010 (and 2011 and higher) and inventor 2010 (and 2011 and higher). if you want to install and run older versions of autocad, lt, or inventor (2009, 2008, 2007, 2006, r11...) in win7, you can use the virtualized "xp mode" available for windows 7 professional, ultimate and enterprise (both 32-bit and 64-bit).
to use the windows xp mode you will need a cpu hardware support. you can detect the hw virtualization support in your processor with the utility xxxxxxxxxxxxx . the windows xp mode add-on (application) can be downloaded from xxxxxxxxx. then you can install the tool through xxxxxxxxxxxxxxxx > windows xp mode.
impossible.I changed pc and reinstalled my 2004 lt autocad on windows 7 home premium.
I did some tests. The strange thing, given the history of home ms, is that it seems to work.
Of course. with due patches, autocad 2010 works on win7. :finger:posted elsewhere by the proscript
