autocad mac keyboard commands do not work
  • Thread starter Thread starter Francesco Bianchi
Francesco Bianchi
Good evening. Everyone. I tried to do a search in the forum but I find no solution. as from title I use an autocad lt for mac version 2023, I have always used the fast keyboard commands (the per line mo per move, etc.), but for two days they no longer go on the mac or on the laptop. I have to click with the mouse on the command bar and write the command. dynamic input is active (fn + f12 or shift+command+d). if you disable dynamic input the commands work, in the sense that I see the command in the bar and sending it is activated. I saw the command next to the pointer.
dynamic input also has something strange: for example to draw a rectangle I could insert and see one below the two measurements of the sides (by acting on tab) now no (see attachment taken from a tutorial).
I hope I've explained and I'm not drunk...
Are you sure it wasn't an update to the operating system to create these problems?
try, if possible, to uninstall the latest updates or, as an alternative, to uninstall and install autocad.
solved, I'm afraid it was actually an update to the latest version of osx. I split my head for days and then the solution was a little more complicated than pulling the plug when something packs. reinstalled and everything works. Thank you.
