autocad map 3d 2014: working area modeling 3d
  • Thread starter Thread starter SchAnt
SchAnt
Hello.
in the office have just installed autocad map 3d 2014, today I open it to make a render and I can not find anywhere the 3d modeling work area.
be clear if I use the map classic display the commands there are all, only I do not find anywhere the 3d modeling mode (which in my opinion is the most convenient to work).
someone knows how to fix, or there is someone so kind to send me the .cuix file of the 3d modeling work area.
Thank you in advance whoever is so kind to respond
and I wish everyone
Good evening
:frown:
Maybe I ran out and made it too complicated.
to be clear what I would like to know is:
:confused:is there a way to add the 3d modeling work area to those present by default in autocad map 3d 2014?:confused:
p.s.
tell me something your silence frightens me!
Hello everyone
I solved!
if it may interest others as I have succeeded:
I downloaded from the site http://www.autodesk.it/ the trial version of autocad 2015 (2014 was not available for download) once finished between the installation files I searched the acad.cuix file and following a couple of simple steps you can view in this video [video=youtube;BlpcHt4sXU4]http://www.youtube.com/watch?v=blpcht4sxu4[/video] I added to my menu the desired work area.
Good evening
: eek: eek: : eek:
the answer of the expert I have to say much simpler and faster:
https://www.blogger.com/comment.g?blogid=29464726&postid=7611251052375416551&page=1&token=1398098942628&ispopup=true"blogger gimmigis said...
Hello anonymous,
you can add the 3d modeling work area to those already available in autocad map 3d 2014, but you have to follow this procedure carefully:
- open the curtain of the working areas (planning and analysis...) then choose, at the bottom, "personality".
- in the customization window choose the transfer tab. the window splits into two parts, on the left you have the 3d map interface, on the right you can load a different interface.
on the right side of the window open the acad.cuix file, that of autocad, which you find in the folder:
c:\program files\autodesk\autodesk autocad map 3d 2014\userdatacache\it\support
- select the 3d modeling work area right, marked by a toothed wheel, and drag it to the left, between the existing working atrees.
press the ok button and the game is done!
Good job
gimmigis"
13 April, 2014 17:05
