sauro82
hello to all:smile:
I do not know whether the following is a question of gis or autocad map 3d:
the file I am using (a shapefile with its .dbf database support files, etc...) has only one layer for geometries (closed polylines and related retinals), which describes all soil consumption. In the database table there is the only column I need, that is the one that notes the use of every geometric shape.
Is there a way (in autocad map 3d) to easily transform the various categories of the column into layers or anyway to create a layer type organization?
I tried to extract geometries from each category and then import each category individually in autocad, but it is too long work. :frown:
thanks in advance to those who will help me
Is there a way (in autocad map 3d) to easily transform the various categories of the column into layers or anyway to create a layer type organization?I tried to extract geometries from each category and then import each category individually in autocad, but it is too long work. :frown:
