autocad mep 2011-12/request info about use
  • Thread starter Thread starter flavio.x
flavio.x
Very precious.
First of all, I kindly ask whether this section of the forum is suitable for the request for information on said sw.
I tried to search for info about it but, apart from links of adesk, sales shops and torrents to "download it", I did not find much. Fortunately there is some tutorials.
Does anyone use it?
Could I ask for some info about your use?
a great thanks to those who can answer me:
Bye!
First of all, I would recommend that you read the forum rules well...
dear tristan,
my was not an incentive to use the torrent tool to illegally download the software, since it is freely downloadable from the addesk site the free trial version for 30 days, well a statement that, while searching for information on the internet on the mep, most links address you to torrent sites instead of sites containing information on the use of the mep itself.
My fault of not having accompanied my statement in this way:
...and torrent to "download it":frown:
I hope I have clarified the pro quo here:
flax
I do not know the sw, but if it pursues the same philosophy of revit, it is dedicated to the projects for the insertion of mechanical, electrical, water plants (m=mechanical-e= eletric-p=plumbing).
Generally speaking, (describe how it happens in revit) the architectural project is imported, therefore using the specific functions of mep, insert the elements (objects) of mep.
For example, for a line of pipes, the main duct is drawn through the "drawing" of a line (spline).
to the same can be added all the specific elements (reductions, fittings to t-y- etc.) that "fit" perfectly to the pipe, to the "points" of connection (crossing), etc.
are then available:
- the management of the lists (different) of the pieces, divided into all possible combinations
- the management of the boards (prints of all plants or individual plants)
- etc.
an example to use it:http: / / exchange.autodesk.com / a...ove-funzionalit% c3% a0- di- autocad-mep-2012
dear gfrank,
Thank you for the answer.
more than revit, acadmep follows autocad and more precisely autocad architecture with which you can work changing work area.
is dedicated to the projects for the insertion of mechanical, electrical, water systems (m=mechanical-e= eletric-p=plumbing).
Yeah!
but my initial question was to know if the questions related to this sw were consistent with this section of the forum, not to wrong.
I would ask questions specifically so that users can find them more easily with the "search" function.
exactly, or import xrif designs and then work on it.
Sort of. with acadmep, it seems to me to understand, it is better to start drawing (in my case I take care of air channeling) the terminals of dispensing and setting the courses of the same and then connect them "also" with lines that then can be converted into pipes from appropriate acadmep functions.
true
are then available:
and here arise my problems to which I would like to ask specific questions as I find quite hostical the guide online.:36_6_4:
here I have not yet arrived... but I will make it:4410:
in the autodesk resources there were good also for mep 2011 and also a discreet tutorial.
what you mention is the presentation of the news of mep 2012.
cmq. also on youtube you can find some short "lections" (let's call them so go'):wink:
then if no one has anything on the contrary I will prepare my questions here. Okay?
thanks for your courtesy (and dedicated time). :4425:
flax
Hello flavio,
perhaps your interest in acad mep is due to the fact that you already know autocad and/or maybe aca; can I give you a tip? deepen the theme but at a time lost it sticks even in revit mep :wink:
@ flavio
the discussion, for now we leave it in this forum, missing a specific one. . .
Hello flavio,
hi tristan :)
In fact!
I'm an old "tiraline." From autocad 11 times.
I haven't looked into it yet and with revit I just can't leave.
you want it to have another philosophy of use, you want me not to have dedicated enough or that I am now a hospice... .
But I think you're right. the future is bim and must be adapted.
who knows that he can not cut out a piece of tranquility to try it.
I've seen a lot of material online and... I mean! I will also be a hospice but not yet to be thrown:wink:
@ flavio
already, also on the internet apparently:frown:
But there's someone who uses it? :wink:
cmq, thanks to the availability. tomorrow I try to post a few questions about it.
Who knows that there is no madman like a hospice like the undersigned:wink:
Hi. gfrank and thanks again:smile:
If you need me, I have a pdf guide on revit mep; sore note: it is in English :frown:
Hi tristan,
Unfortunately it is sore. I know English as Arabic and Chinese (=0):frown:
from today until the end of the month there is in promo at 40% on ibs "autocad mep 2011" (unique copy).
What about this in English? (I think I understand)
I "butted" an eye to the "guide for new users of revit mep" on the wiki help of autodesk last night.
I think it's a good starting point.
I read that you can do the analysis of the loads for heating and cooling....mmh... interesting mooolto!
we feel how much I learned a little something.:smile:
I think if I can work in 2d, I leave acadmep.
Hi. sadan e grazie! :smile:
can I reexhume this thread to ask tristan pdf on revitmep? ?
I would be interested in the "passage" by autocad but I don't yet know what you can do because actually of info on revit you find but mostly are on its use in architecture.
Let me know:
bookmarks
