[autocad - public] custom page size replaced by the program
  • Thread starter Thread starter ing_82
ing_82
I have a problem with the autocad public command.
if I use it by telling them to use the plotter defined in the page settings, the print is generated correctly for each file (print is pdf), if instead select "pdf" to have a unique file immediately, one of the custom page formats I set is replaced with the page format "arch page entire d (36 x 24 inch).
the correct size of the page would be 630 mm wide and 891 in height.
all other formats are printed without problems, only this format is not used correctly.
I tried to memorize the size of the sheet as both 630x891 and 891x630, but the effect is always the same.
ideas?
