ieu
Hello I would have a problem:case 1) a program gives me a dxf file in which there are beams in scale 1:50 and of the sections of this ultratime next to scale 1:25; a width that in reality is 30cm on the model gives me 60 units; for the section instead the side 30 cm me from 120x.After having saved it in dwg to be able to work on it, I prepare my sheet for example a4 and then I go into the layout,imposed by management settings page the characteristics printer (or pdf creator or from dwg to pdf) leaving scale 1 to 1 .creo the window,
the version is autocad 2020 for students .I ask you :1)from what depends this error?2)because beams and section are flanked but in different scales,to keep the respective stairs I have to make a window for each or there is a system for having them in a single window and keeping the stairs?
