autocad structural detailing 2013 - system requirements
  • Thread starter Thread starter supermonomatteo
supermonomatteo
Sorry if I keep posting in the autocad section, in the absence of the specific section.
I recently downloaded the 30-day trial version of structural detailing 2013 64-bit version. I am experiencing considerable slowness and impossibility sometimes to perform some operations even with simple structures.
For example, I had a good time modeling an industrial 3-door shed with 8 columns of hea 220, portal beams and arches with custom profile. the modeling of the custom nodes and profiles is very good and precise, but the program is tremendously slow, especially during automatic saves can also reach 50 seconds of total block. to switch from a layout to the template space takes 20 seconds, not to mention when you have to update documents under the location tab. then when you try to export the layout into the model space, you often get the program closing after a couple of minutes in which the same remains blocked.in practice the program so it is not usable even for ludic purposes. possible that hardware resources are not suitable for sd 2013? .
my pc is so configured: so windows 7 professional,processor i7 2700k 3.5 ghz ,16 gb ram, video card ge force gtx 550 you (I am waiting for a nvidia picture 600).
thanks in advance for the answers.
Yes, in fact as requirements there should be great. It is true that I had the opportunity to try the 2012 32-bit version on an obsolete repentum 4 with only 1.5 gb of ram and it worked, though slowly, just to allow me to perform the tutorial made available by the autodesk. now on a much more performing machine with 64-bit operating sitema I do not see big improvements. is there any incompatibility due to hardware? the fact that my video card is not among those certified, can you create all these problems? at the end of the week I should get the picture 600, and I will climb it immediately hoping to improve.
This is the shed I shaped and put on the table. the program I like very much, both as modeling and as putting into the table, but in these conditions it is not usable if not for game and with very small structures. I hope to be able to resolve soon so that we can assess it well for the remaining days of validity
you tried to open the dwg with "normal" autocad, the one without the ads profile, if it continues to trouble you have something that is not well set.
the attached image is a structure made in cadworx, which in dual-core PC (core2duo) with hd4830 ati turns without any hitch, the shift from model to layout is immediate.
attach the dwg that in uff ho ads 2013 and verify the problem.
bye
p.s.: for site administrators; autocad structural detailing would need to be in the autocad forum, maybe in a specific directory.
