autodesk vault professional 2017 works?
  • Thread starter Thread starter 3°minore
3°minore
:bekle: hearings: we are finally going to update to the version of inventor 2017 :36_1_11:
to date I still use 2011 with vault basic 2011.
it was thought to pass to professional vault 2017.
I have a very bad experience with the vault basic because it doesn't work: It is very slow, it creates errors on the net, and it is lost hours and hours for trivial operations.
Does anyone use professional vault with satisfaction and/or have ever had problems with the operation of autodesk vault?
I use vault basic from the 2015 version and it works very well.
Of course it has limits that are overcome by the professional, it always depends on what you have to do.
considering that vault basic is included in the product design suite you might start from that and try it, then in case you value the purchase of the professional.
According to me an important thing about the vault is set it well, I recommend doing the thing to an autodesk technician.
unless you have a good computer inside. . .
from 2011 to 2016/17 there is an abyss, in the best.
2017, at the moment and as part cad, I think a bit 'acerba, better stay on 2016.
the problem then is that: We've arranged and we'll have something wrong.. .
However it is the time we also change the machines and the server, and the technician is sure.
but today you install the 2016 or 2017 version?
