automatic axis
MARCOC
hi..domanda i use the command automatic axis lines to create axes on a circular set of holes...inventor creates axes like the figure...I would like to know if there is a way to prolude the axes at the center of the ovvimante circle not manually that you can not match the final point of the axis with the center of the solid... thank thousand
