automatic ballpoint
  • Thread starter Thread starter liga76
liga76
as from title, I have a set made of 60 items and I would not manually create a ball for each item, I wondered if it was possible to create an automatic ball so as to save valuable time, thanks in advance for your answers.
you must first assign the numbering within the poduct by clicking the "genera numeration" icon.
then go to the 2d and, with the frame of the activated view, choose the "create balls" icon (in the creation menu).
done.:finger:
Once you create the balls, you have to reorder them all. After moving them manually, you can use them to align and detach them, the appropriate icon on the 2d "position of elements" (the icon is represented by 3 small squares indicated by 3 arrows).
There is no automatic alignment.
...but when I try to reorganize them, they move only to snaps, instead I would like the movement of balls to be totally free. . .
I move the balls smoothly without any problem... I don't understand
Maybe try to move them by holding ctrl, but I don't think anything changes.
...anke holding ctrl always goes to snaps, I would not want some option to be active that prevents the free movement.. .
It can be, because I saw that we have the same version of catia.
proma andrae ne menu tools/options/mechanical design/drafting/creation:
I only have the flag on analysis after creation and creation of a ball for each occasion. . .
I don't know what might be
Good morning
I reconnect to this discussion because I followed the directions but when I make "create balls" it creates the balls with the name of the piece and not with the letter or number.
Where am I wrong?
is because you messed up in the ball field that default is on numbering. . .
go to menu/options/mechanical design/drafting/ annotations and detailing/pallining and selections numbering
Let me know.
In fact, I remember having touched that setting because on another occasion I needed to have the name and not the letter.
