automatic bom balls
  • Thread starter Thread starter Brisco1994
Brisco1994
Bye!
if I have a finished explosive set to put in 2d consisting of example 50 rows of bom table.
Is there a way to order balls automatically?
when you create them from create bubbles, they are put in scattered order and you have to go manually.
it would be appropriate to have ordered them in certain areas and at the same distance.
I would like to avoid ordering manually every time.
Thank you!
in the dtl file that manages the options of drawing there are items to manage the balls.
but are there examples/indications on youtube or manuals?
basically in the company it takes 30 minutes minimum to fix the balls of the explosive, we would like to avoid...
Usually you rely on companies that do business configurations and do training. I don't think you can find manuals or videos for such a specific activity to me or that you don't watch the help online.
Hi, Brisco1994, I try to answer
After entering the bubbles go under table and down to the right where there is “general” selections “botle dist base”. by making a window select all the bubbles already inserted and with “bubbles reset” (you also find it in right mouse button) the appropriate window appears where you can insert offset from the view profile (I use 10) over “create corresponding snap lines” and an appropriate value in “minimum distance between the bubbles” (I use 3). what you get is not definitive but is a great start.
Hello, fausto!
I have already tried to do with the right button reset bubbles and also put the necessary offsets. problem having like 50 bubbles, the system tells me that it can't do it!
if the error message is something like “the options and values...” reduces the value “minimum distance between the bubbles” (my 3 was a tip).
after you have “reset” the bubbles and hooked to the new lines of snap, if you translate this last bubbles follow accordingly.
