STAP
Good morning,
then after several experiments I arrived at this dwg mechanical plants,
where the cartiglio is an external reference that is equal to all layouts and various fields in red within it are precompiled according to work.
The layouts are automatically renamed with a lisp that renames them that way and the attributes in the layouts change accordingly according to the window used and the layout name.
Now I ask myself: I would like to change the text in purple (which is different for each design based on the plan and the plant), but the cartiglio block (which is an external reference) is the same for everyone and if I create an attribute in layout then it will be the same for everyone, since each layout will then derive from the previous one.
Do you have any advice?
