automatic color change in catia
  • Thread starter Thread starter Roberto S.
Roberto S.
Hello, can someone tell me where I find in the standards (after entering as administrator) the parameter that modifies the "automatic" (or base) color of solids?
the reason is that in my models the white color is what indentifies the processing with the lowest (weight) degree of tolerance.
if I change the general color of the solid, then in the conversion of the files in step, I lose the colorations of the faces obtained with the custom matrix, and if I leave it so I should go to change color to each processing (smussi etc.).
I don't know if there's a possibility to change the color automatically in standard. . .
I think you have an export problem in step, i.e. you are using ap 213 that does not keep colors, but you have to set the step ap 214 (which keeps them)
instruments/options/general/compatibility/step/export/ap/214 iso
Let me know.
Let me know.
Bye. Thanks for the answer, but it's not. I have already set standard 214 and the colors in general keeps them, except for the processing obtained from the custom matrix command to which I went to change the color of the faces and some other operation. This problem has been encountered since I passed from r19 to r22 and now to r24. the bizarre thing and that if amount directly from toptron the problem is not there. Thanks anyway.
