automatic generation table with values
  • Thread starter Thread starter Alfred_V
Alfred_V
Good afternoon to all,
I often have to select polygons of surfaces on autocad and then report the value in an excel table outside autocad.
I ask you if there is the possibility by autocad map3d or other autocad (civil3d or other) of being able to generate in autocad itself a table excel with the values of the selected polygons, like this:222.webpattach photos as an example of the dwg:111.jpgin the photo I have highlighted with 3 different color polylines (red-green-yellow) the surfaces I have to report in the table, of course this is one of the "x" sections of project, so I ask if it has already happened to someone to be able to automate this process.
Thank you all.
if we talk about simple autocad polylines, you can use the remote control
Good morning Tristan, you're right, I didn't think of this command initially...I saw the answer I studied a bit the various exports, however this implies that every polyline/object for which I want to extrapolate the information, be thought in this optical before being drawn so then the export is faster (the selection for export). so I have to improve in the initial design setting to find me well after. Thanks for the tip.
Good morning, I put myself in this discussion. . .
I have autocad 2023 lt... in the command prompt, I put out, but it tells me that it is an unknown command. . .
thanks in advance for the help.
thanks for the prompt response... and there is no alternative solution?
