automatic name / material selection etc in full
  • Thread starter Thread starter MarcoDap
MarcoDap
Hello, everyone, this is Marco d'April, it's a pleasure!
I would like to ask and know if it was possible to automatically insert the name linked to the chosen structural component in the features tree (e.g. viga 100 x 50 x 6.35), directly into the section "propietá ->propietá configurazione -> nome". the propietá section of which I speak would be the section where by filling with the data, name, material, raw material etc, we succeed, in the design configuration (assieme) by inserting the table "list of materials", to see the characteristics of the object with the inherent specifications.
to explain myself better I make an example.
for example when I insert the mass on the right in the drop-down menu, by typing "mass", the corresponding value automatically appears without having to type it manually.
This is what I would like to make automated, the appearance of the name inherent to the structural component, simply by selecting it from the drop-down menu, then create, like, a link between "name" and the component.
I hope I explained.
Thank you in advance and wait for a return.
March of April
I don't understand. the structural members are managed in part multi-body and not in combination and in these objects there are the properties automatically, once defined the library.
on the forum we have already talked about it.
if you want to give names to parts instead of having a list of designers, materials, custom properties, taking from a list you have to use the builder tab and create the cn mask the cells pointing from a drop-down list (txt or xlsx).
you can't take the name of the features in a part and use it automatically as a description.
You may try to make a macro, but it must be launched separately and not independently....and however may not be correct.
as in the section "propietá -> name of the propietá" we insert the term "mass" from the curtain, moving on the right into "value in text", clicking again on "mass" in the curtain automatically appears the value of the mass, so there is a link to the base that binds the project, with annex material, to the automatic insertion of the numerical value of the mass.
I would like to do the same but simply by name.
For example, the chosen structural element is viga 100 x 50 x 6.35 (name that appears in the features tree), I want that in the "text value" section appears "name" and that by clicking there is the name of the structural element without having to write it manually.
copy and paste $prp:"sw-file name" in value...I don't think you can change the list if you want you can change the part template with this value already inserted. 1719500531646.webp
1719503453400.webpI try with a photo.
looking at the photo, once assigned the name, in this case "matéria-prima", I would like that in the curtain menu open to the right (red square) there is the voice "matéria-prima" in which clicking on it automatically appears "abas iguais..." as it was practically done regarding the "material"
