avoid section on bodies.
  • Thread starter Thread starter Gabriele SWX
Gabriele SWX
Good morning, everyone.
I have a multibody part of which I have to make tables with section views.
I would like that in the section views some bodies belonging to this multibody part to be dissected, while others do not.
in the case of a set is simple, in the section just select the parts that you do not want to dissect, but with the multibody parts I did not succeed.
Do you have any suggestions?
you can't do it in the multibody, but in the axieme when you uncheck a part to treat like the tree, the edges must be seen not all open and empty.... I attach image. the tree pos. 3 is unchecked but the sight is not correct; missing the edges I can't see.
never happened, check if in 2021 they entered some option that could only take the contour.
