axial section of the mechanical component.
  • Thread starter Thread starter bunza
bunza
I must represent the enclosed reducer in axial section (the one circled in red and the support with the lids), but from the explosive view I can not understand how to mount some pieces. Could you help me out? Thank you all.
I must represent the enclosed reducer in axial section (the one circled in red and the support with the lids), but from the explosive view I can't understand how to mount some pieces.
Perhaps presented, as required by the regulation you have approved at the time of registration and you will surely read. . .
coming to your problem, it begins with clearly indicating on a new image that you will charge in the prosimo post which are these "some pieces" that you do not understand how they should be assembled.
edit: I'm sorry, I saw the presentation you made. When I answered, I only saw that message.
Unfortunately there are several things that I have not understood and are those circled and numbered so that we can be more precise:
1)In the two trees circled in red there are two lines (the ones circled) that I think are exhaust gorges because I don't seem to be changes in diameter of the tree, but what do they serve so? Moreover, do the spacers cover them in the aid?
2) the spacer that goes to replace the bearing, once inserted on the shaft, is in contact with the toothed wheel 5?
3) how do you mount the spacer and the circled bearing?
4) the inside of the support is for me a true mystery since from the asonometry I can not understand much how it is done. Any disappointment on the piece?
5) Finally, I cannot understand how the lids in question function once they are inserted into the axieme.
Thank you very much for your patience.
In my opinion if you have no better designs than these you should redesign in 2d or 3d all components and mount it for really this reducer. so to the eye there are no strange things in this reducer. You just need to figure out what's ungrateful and where the bearing bars are inside the main house. for lids there is really little to understand why inside there is the seat of the bearing and the seal.
regarding the circled lines that I see very badly with the smartphone should be rigor of logical seats for seeger to block the inner ring of the bearing axially.
to understand how the whole train is mounted you have to look at the acenometry in this blue. the inlay of the second axis is all mounted to the right of the case together with the input axis where they deceive the two.
