axiemi: guided repetition and couplings (2 questions at the price of one)
  • Thread starter Thread starter BIXIO
BIXIO
1- in a set are repeated n times the same parts with the same combinations, is it possible to create a group of such parts without creating a sub-axieme?
or at the limit it is possible to create a sub-assieme that in separate puts me all the parts of which it is composed, selecting the distinguished first level?
example a bi-rotary conveyor, the straight is composed of 2 rails and a leg, which have distinct codes, but their use in 80% of the times is together.
2 is it possible to activate the anchor points of a set?
example always convoyer, the track will have a face in contact and 2 hills, how can I do so that every time I insert this together in a set ask me the couplings?
Greetings
Hello.
in response to the first question;
you can make a repeat of the elements, if it cannot be linear or circular you can create it on holes repetitions created on a support part.
ok until it is linear or circular, but for example if you have a development like the roller coasters....?
If I'm on a plan,
create a mother part a sketch with a spline and on it generates points and holes, and then create repetition on it.
Greetings
bixio allowed me to edit the title of your thread.
in the future he tries to use titles that can be traced back to the subject, so that if one should do a search for keywords it is easy to find answers (what was he looking for? Two domande. Prezzo.? Come on, a little fancy.
Maybe I didn't properly express your problem, but then it better explains what you need, maybe post some examples that always help.
Mar
also work in the separate as requests it is possible, when you insert it in the table selects "with recess" and put "flat numbering", then click on the left side of the separate and then open and close the assemblies, deciding which to show the contained parts and which not.
