axis origin for hole table - se20
  • Thread starter Thread starter mata85
mata85
Hello, everyone.
I looked for arguments on "Table holes" but I did not find something specific similar to my question.
I ask you if you can in the draft environment, change the orientation of the axles or the values in the table.
I attach image to better understand my problem.
after placing the axes x1, y1 and selecting the holes in the table turns out negative the positions y.
is it possible to make them positive and therefore consistent with the y1 direction in the view?
it is not possible; solid edge considers the values from left to right and from bottom to top as positive while from right to left and from top to bottom as negative.
the only way you have is to move the origin and direction of the reference axis.
I do not have under hand drawing regulations but I believe that the direction of the arrow and origin position determine the negative or positive sign of the values in the table; opening an ir with these assumptions perhaps (but I would not experience much) is accepted as a problem and not as a request for improvement.
in any way it is worth reporting the thing
