Micim
I pose my problem: I have a design in autocad with some lines having a thickness of 0.09 and 0.20. when molding one or more layout using dwg to pdf, in pdf the horizontal and vertical lines are seen well, black (as should be), but the tilted lines are little visible (become gray). using a virtual pdf printer, this problem does not happen, but I prefer to use dwg to pdf to export layers and print multiple layouts in just one pdf.
Can you help me? Do I need to set something specific? use autocad lt 2016.
