Merolla
Hello! !
I am designing a cycloidal reducer and to reduce the vibrational problem I have to balance the centrifugal force of the eccentric. on the web I have seen that the most common solution is to use a two-stage cycloidal reducer so that the second cycloidal disc complies with this centrifugal force.
you know how to explain (also through direct links) how do you get this compensation? Do you know other methods?
