bar in high
  • Thread starter Thread starter PiegatoreSolidworks
PiegatoreSolidworks
I can add on 2010 the property voice where you change the data of the side file next to maybe that of "options".
Thank you and excuse the rush!
Right-click on the toolbar and then 'personality'.
use the help no?
I apologize for ignorance, but I knew that! the speech is that "ownership" (the one in the file menu) is not there. or better you can add between the mouse gestures but not as a top icon next to that of "options" or to the quick menu....
Am I wrong?
Am I wrong?
disassembled a brush of satin sheets that is this:
okkio, if you do not have open documents, the property item is not default. :smile:
Am I wrong?
go to the command tab, look for the command and do drag&drop wherever you want.
I found that, too, but it's not the "property" I mean... what I'm looking for is in the previous post, that of mike. is it possible to add that "ownership" on the quick menu or on the top bar without going to search all the times from the file menu?
exact mike is what I'm looking for! I saw that you can add it on mouse gestures but I would like it on the quick menu as an icon... is there a way without going to take it from file - property?
I suggest you put it under the "s" button.
or, as I prefer, put it on your keyboard, for sempio alt+p.
See you.
See you.
for now I put it under the "p" button but I wanted to put it on the quick and mobile menu that appears when you press the "s" button. the dilemma is: how do I do it?
after pressing s, click on a free space with the right button...
you mike the theory I know, in fact I deeply changed the menu we are talking about! But I was wondering where I find the property we're talking about? the only property is under the standard group but it is not the "property" to which we matched the "p" button....
Hello and thank you.
I don't understand the problem, if he's not there, he'll be somewhere else... who seeks to find.
What I said from the beginning is what he's looking for.
but if he sleeps... it's not my fault.
2 pages to explain how to add an icon...we are to fruit.
One of them disappears, another one comes.
alt... alt... you are trying with 2010... while I have 2011...:frown:
As I told you, I couldn't find him!
Well, it does nothing, it means I use the "p" key of the keyboard I set to call it back!
thanks anyway both to you and to solid user for the attention.
....ok, I'm tired, but in the end I think I'm a bit of a reason too! Anyway I won't write here anymore, I don't want to bother you about the other super users who are already geniuses.
(Add an icon I know how to do it for at least 2 years!!! ! ! ! ! ! ! )
Good night.
(I will sleep as you say but if you read well you notice that I have the swx 2010!)
Good night.
(I will sleep as you say but if you read well you realize that I have the swx 2010!)
I downloaded the image 'properties I look for' and that's what I told you to look for and also shown with an image.
do not do the offense and it is not even the fault of the version that as an icon there is from a couple of versions.
in my opinion needs a little more tolerance, some users do not
by profession the designers, engineers and everything (I first, I am a metal constructor.. ), which need more help.
If one wants to help him, he will not stand on his altar and no one touches him.
I have expressed my opinion, do whatever you want.
since I am not so dumb as you say you look at this thing opens me with the icon you kindly indicated me you (remember that I have solidworks 2010 sp4!!!!).
thanks also for the appreciations you have for free commenting on the previous post of mike....
Look, I have no words.
you can make things simple to complicated through useless.
do whatever you want and follow the advice of who you want.
I told you the procedure, you did everything else and you find yourself like this.
Since the good mike, besides defending you, has also messed up, let him help you.
I think what you're asking is available since 2008.
