simdifeb
Hello everyone, I am a university student and it is the first time I write in the forum even if I consult it very often. I hope I can solve this problem.. in practice in the module of the lathe machininig I chose a 5-axis machine to carry out a coarse operation by bare of a hole that from 188 mm steps to 199 mm in diameter. the characteristics of the insert and carry insert I collect them through a simulation of the processing on sandvik. I have been proposed a tool that has a max diameter of 218 mm and a minimum of 180 mm, the problem is that then on the casket, proceeding with the processing of barenatura, the parameters are inserted on a bar of alesaggio (which I did not seem wrong, but to solve the doubt: is it right? ) and the maximum cutting diameter of 30 mm.
How can I perform a barening of larger holes?
