basic sheet module - change table thicknesses
  • Thread starter Thread starter Stemox
Stemox
do you know where to change the sheet thickness table that can be associated with a part?
I have repetitive and some missing, I would like to update it once and for all.
if your installation was made by a softwarehouse fixed with the centralization of the settings, you should look up the reference table with various materials and thicknesses, open it with wordpad and change it by hand; if instead there is the basic installation then in theory to delete just get to your table, select the material to be deleted and then the "elimina" button; while to add just click on standard, then on the new thickness, assign the material and the next use of the command you will find the new thickness inserted in the table.
In general it is fine but it is not so simple.
My is a softwarehouse installation but I think the basic sheet module remained as standard installation ...so difficult to find.
