batch per stampare pdf
gtsolid
Hello everyone
I am creating a batch that executes the following commands for deteminati files:
Open the door
file
_
_
_
_
I would like you to print each of these files in pdf: print extensions, horizontally or vertically, adobe pdf printer, target folder the same as the single file. as a print style what you use here in the company.
Can you help me?
use a script file.
in the forum there is a great excel that optimizes the operation and contains some roprio examples of print
I'll take it back.
write the code (which will be valid for all files)
upload files
create the script
or throw.
but if you also need to discern at the opening if the file is printed horizontally or vertically the thing with the script is not feasible.
if instead you do this division upstream (divid in format the various files) then it is feasible
