tillo
I'm working for my graduation thesis on a structure analysis on patran.
I have to reconstruct the set of the tree of a sailboat in msc patran 2008 r2 and therefore I am working with elements 1d cbeam and rod.
I am having problems in the joints between beam(shaft and boma) and rod(x all steel cables) because being beams under bending the rods that I joined with mpc rbe 2 binding the translations and leaving free the rotations do not follow the deformation but I only have a deformation in the final element that does not make sense.. .
I also tried to rebuild the cables with beams with very low inertia modules but I'm not convinced.. .
What do you suggest to do to model the ropes and beam-rod joints?
Andrea
Andrea
