bearing
  • Thread starter Thread starter Mario91c
Mario91c
Hello.
Do I have to do the way that the outer part of the bearing remains fixed in the ''material'' in which it is inserted, and the inner part ruotes with the tree.any one gives me a hand?
if the bearing is a part the only way is to make it rotate "all" on the tree. otherwise create a bearing axieme, outer ring + inner ring+sphere, then in your main set put the bearing in flexible, constraints the inner ring with a tree top on which it is mounted. in this way if you desire the rotation of the shaft, this also drags the bearing
Yes, in fact I managed to do it even before. the bearing rotates everything. However, although they had the same constraints, the bearing on the other side of the tree did not rotate.
excuse the banal question but the bearings have a dedicated library or do I have to create it?
I answer myself to create a historian, I found the section dedicated to inventor but I did not find the series of low or better we need a bearing 150/120/16 and I did not find it.
Any ideas?
Any ideas?
When someone talks about creating a library of normalized parts with inventor, very often it's because:
1)does not know that the content center exists:cool:
2)He did not look at us:cool:
3) He looked at us but does not find it.(In this case it is good the council of davide 75):cool:
Anyway:
This bearing, will have a theme and a standard of unification?
120/150/16 is a banal 61824 (the bearings are indicated to start from the hole)
then:
center content
- tree parts
-ball cushions
- deep groove ball bearings
-skf (for example)
and there you find your bearing.:biggrin:
you tarkus the bearing is that I did not see it.... Monday I look better following your advice.... thanks
tarkus, nothing or I'm delayed or I don't have bearings.
Maybe the first
When I insert a bearing that gives me the opportunity to insert the bearing measures I want and then look for it with lightning I find nothing of what I need.... .
Where am I wrong?
sometimes selecting deep groove bearing comes out without giving me the chance to act
tarkus, ...................................................................................................
Maybe I'm late, but I didn't understand what you're saying with this speech...:confused:
Of course, when I write fast at work I forget to connect my brain to the hands:smile:
then I try again in iam environment I have the possibility to insert a bearing by clicking in the dedicated icon, I appear a screen where I can indicate the measurements of the bearing choosing also what type of bearing I want...to angle contact, deep groove and other, once defined the clique parameters on the lightning and there is a list of bearings, right? ? ?
Here I am the bearings I want never to find them.
In fact sometimes choosing a family of bearings compared to another one I plan the program.
I hope I'm clearer.
I hope I'm clearer.
in your project file you have selected which libraries should draw the c.c. (iso, din ansi etc.)?
