ottoper
hello to all, I am a mechanical engineer but, for some "absurd" reason, work in the field of construction. One of the biggest problems I'm facing is the choice of a 3d modeling software that allows me to be able to make computations, then extracting the various quantities modeled (quantity takeoff). I used for years catia, solidworks, inventor, etc. in the mechanical field, therefore the only modeling that I know well is the parametric variable one. I tried to use revit, but I did so much effort, because I found it difficult to get out of the preset patterns (if, for example, I have to join three walls, maybe not orthogonal between them, why should the software create the junction according to a logic that is all yours? I am used to model every single detail, so a software that tries to "invent" what I have in mind slows me down and does not speed me in any way!). Then they recommended me vectorworks that is already more like a mechanical modeler, even if I don't look very well with that, especially because I can't generate the basic sketches of the features quickly and then because I can't find an effective way to bind the models to the absolute reference system, so I have blocks that "go" in space to every erroneous click with the mouse.
I ask you: Do you know a software that is variable parametric, that allows me to carry out the quantity takeoff of the individual models and that has, possibly, a contained price?
Thank you all!
Thank you all!
