mandorlim
Hello, I am learning to use pro/engineer wf4, and I asked users who use this cad which technique they recommend for the execution of multiple smooth holes or threads that are.
I try to make an example:
I have a sheet plate on which I have to go to perform a whole set of holes not necessarily pattern.
with other cads (solidworks and inventor), the function creates hole is based on a sketch, then you create the sketch, and you go to select the remarkable points where you want to create the hole. with the same function I can then create 1 or more holes regardless of the points I created in the sketch.
with proe, the hole function allows me to place only one at a time, giving it references from time to time, or is there something wrong?
and then you have to resort to the pattern function, to create a series...
but if the holes I have to create are not in series? How is it better to proceed?
repeat the hole from time to time giving it references? or create datum axes based on a sketch and take them as reference for holes?
