biforca scale
  • Thread starter Thread starter VLK
VLK
I would like to build a monolithic staircase that joins the ground floor on the first floor.
this staircase begins with a simple ramp say 7 8 steps to get to a landing of any shape. from this landing I would like to leave 2 ramps let's say one to the right one to the left that arrive to the first floor.
simple conceptually but in revit it seems to be an enterprise.
Can anyone recommend the best approach? Thank you very much
v
ps clearly I have already tried by making the 3 ramps like 3 separate stairs but there are a lot of problems counting the fact that the nn stairs can be combined with the merge geometry command so lines of union that nn should be there, the 3 suns that nn are perfectly connected etc.
the solution is the one listed at the end.
possibly the intermediate plane execute it with the floor command, then:
- a staircase with 1 ramp from the ground floor to the intermediate floor;
- two stairs with a ramp from the middle floor to the first floor.
the start/end lines (first/last lift) must match with the profile of the floors; if you want to "eliminate" the lines of union between the ramp and the intermediate/sbarco plane (solai/pavimenti), in the specific views (viste di tavola) a command "invisible line"
I try to say mine, I would use two stairs; initial steps + shelf+grades sx; initial steps+ripiano+gradeini dx, basically the first ramp divides along the axis
bye
mb
bye
mb
I tried this solution as well, graphically it is better than the scale divided into 3 ramps but remains the problem of the annoying division line (in all plants sections prospects etc.... .
.... at this point I ask: is it possible to select this broken line and replace it with an invisible line in a view and make it invisible in all other views without having to always remake the process?
thanks to the answers
v
I use the program more and I like it but I still feel a little young especially in the controls a little more articulated like the stairs, railings etc, you think?
