binding a screw on axle
  • Thread starter Thread starter iron72
iron72
Hello.
I created a detail that has a circular asola, inside it has to pass a screw.
in assembly I would like to bind the screw axis to the circular axle as I can do?
I tried to build another sketch on the asola to create a semicircle that passes on the axis of the asola and leave it visible in the assembly for a possible bond that I can not get.
see photos:
Then I finally got rid of an offset, the radius of the axis of the circular axle, with the axis of the screw.
with the right button you should be able to select the virtuasle axis of the asola. search under the voice other selections (it seems in Italian)
