black print of ole objects
  • Thread starter Thread starter emanuela86
emanuela86
when I go to print a drawing with an ole object (file in excel), in the drawing and preview of print I see the ole object well defined, but then I print a black rectangle, it seems almost do not recognize it.. .
This problem I have responded since they changed my computer, I installed windows xp, reinstalled the program, printer driver etc...
to discover the culprit of malfunction, it is enough that you print to a pdf file.
1 If even the adobe reader print is unconformed, then the fault is autocad.
2] if the pdf is printed well, then it is the fault of the printer driver not 100% compatible with autocad itself.
tertium non datur...
2] if the pdf is printed well, then it is the fault of the printer driver not 100% compatible with autocad itself.tertium non datur...
[Bleep] for granted that all settings are correct, many times complain, however, inconveniences like this: one of the innumerable that appear with prints cad under windows.
that lamenatate comes from the fact that autocad allows to hook a raster file, excel, word, jpg, etc. (ole objects) to a design and this is clearly defined to monitor, as if it were a unique document. autocad, however, does not work with these programs.
when you go to print, then, the complained problems arise; this is due to the fact that the autocad print driver can only print the traits made with autocad.
so that there are no more sophisticated drivers that, overlapping, allow to obtain the prints of the objects listed above.
we have these drivers, third party product and recommended by the same hp and autodesk.
on our pages you can read the features
www.paolocasella.itdrivers
> > > the cad and prints
just don't use m§@*a stylus... why don't you use a data connection with excel?
Why don't you use a data connection with excel?
..maybe not to force the recipient of the .dwg to have excel installed.
I wonder if it's openoffice enough. [previo associazione .XLS <--> CALC] or even the free excel viewer of microsoft: I will try as soon as possible.
non serve...
Let me explain better, assuming the following scenario.
in your pippo.dwg connects you to a pippo.xls, so that every change in the excel file is automatically reflected in the acad design.
Now, if you email the pair pippo.* to someone, that someone must have excel installed, or just openoffice calc instead of microsoft .xls. ?
if you need to change the xls file you need excel even if it is an object:wink:
I confirm, and I add the following.
I just opened This is what Pair pippo.* on an autocad impeller on PC without excel, but with openoffice and microsoft .xls visor.
had, the table is displayed and printed correctly, but there is no way to make it update the values dynamically (as it happens with excel).
as to the problem of emanuela86, I would try to play on the variables olestartup and olequality. . .
I solved by opening the property command, selecting the table and changing in various > print quality > from black and white to standard quality graphics.
