pluncake
good morning to all, do you find there is a procedure/lisp/script to block only the scale of the layout windows?
the window block I use it but I would need to leave only the unaltered scale while leaving the possibility
to center the view with the pan.
currently within double click, unlock, center, block, exit, but as you well know the wheel is really birichina, it is a moment to touch it and change scale.
