mazzetti68
Good morning, everyone!
from a lot of work with dynamic blocks, but today I came across a function that I never knew there was and what it was for.. .that is dynamic control... in a few words look here:
here the dwg:View attachment WELD After vis States.dwgthis also:http://forums.autodesk.com/autodesk/attachments/autodesk/154/16561/1/multiple%20visibility%20states.dwgI needed this because I didn't think it was possible to activate more visibility in the same block
, but I just can't use them, and I really want to understand how they use it, which is from a couple of bears I look for on the net but I didn't find anything (except the example attached). ..someone who uses this feature knows maybe give me some tips to find tutorials (always that exist) or other material?
thanks in advance
hello and good day to all
here the dwg:View attachment WELD After vis States.dwgthis also:http://forums.autodesk.com/autodesk/attachments/autodesk/154/16561/1/multiple%20visibility%20states.dwgI needed this because I didn't think it was possible to activate more visibility in the same block thanks in advance
