blocking
  • Thread starter Thread starter xxfast
xxfast
Good morning, everyone.
I would like to create a block of superficial finishing symbols, as in the image.
How can I do that?
with the creation of blocks I can not.... .
strange, but I had already tried and so doing, it does not make me select the symbols of roughness, but it only takes the line of sketch that lies below....
I'm sorry, I worked on an old block and I didn't notice how it was.
that of the video is made with lines and notes, not with the annotation of roughness that in fact does not take and in the specific guide of select sketch entityit may be useful to you, if you have not already done so, to create styles so as not to write each time the value; then saving the model you already have them ready. see video
for general roughness to be inserted in the cartiglio you can insert roughness in the properties of the part and recall them with a note. see image image
View attachment salvare stile rugosita.zip
Okay.
I will use the styles.
sin that with this command you cannot create a style composed of multiple symbols.
Perhaps I will also try to explode the lines of the sup. finishing symbols with autocad and subsequently create blocks.
it would be interesting that they implement the recognition of the values of the inserted roughnesses and create a table that groups them.
autocad mechanical for example does
How can I do that?
I don't use the blocks for that. I use symbols with text for brackets and point and comma between symbols. once you align objects with alignment tools use the command group to move them all together. If you make the copy-paste of a group you can take it all at once and move elsewhere. for repetitive notes instead of using the blocks I have a table (without models) in which all these notes take off. It is a multi-sheet table with annotations divided into topics, such as welding, sheet, specific notes of a specific customer, etc...
when I need notes I open this table (link on the desktop) and copy/neck the annotations all at once without having to enter a block for each command. the design file is unique in network for all stations.
great idea:finger:
Good morning
Excuse me if I reconnect to this post.
following the post, I created roughness and saved them in the styles folder. I would now like to create, since from what I have understood you cannot inside the cartilage, a caption as in the image of the 1st post, with vati types of roughness, including brackets. I hope you understand. with solidedge, it made me automatic.
draws a line, put on the roughness, add the brackets and as explained in the post #9 use the command group (strumenti> alignment> group)
thanks massive, but I did not understand how to insert the brackets, from known command? I'm sorry, but I have a lot of solidwoks I can't understand. I am confused with the options of the solid edge. but then to copy them on all tables, do I have to act as edit sheet format?
Did you do the internal tutorials? serve to understand the basic commands and logic of operation.
But did I not understand how to insert brackets, from known command?
the brackets insert them with the known command.
no, unless you want to always find those roughnesses on all the drawings that you will create. However it would not be a retroactive change.
various methods:
-use the method of post #9 and create a design on which to paste all the typical annotations to then withdraw to need.
-create onlythe sketch and brackets on the sheet format leaving the space to insert the necessary roughness on each specific design
- create a space in the chart where to insert the symbols of roughness in the form of sketch and put notes related to the properties of the drawing
you have done all the tutorials and I am dealing with them as I encounter difficulties. Things are so many!! !
the method of post#9 I created it, only I don't know why, but when a group, everything comes out. I saw with a client that to incorporate roughness when necessary, he had a list of wrinkles included in brackets and when necessary predominate those he needed.
I'll see what I can get. Thanks again!!!
means they were blocks. The list you saw is a file indexed in the project library.
to better understand: open the bread task(ctrl+f1), select project library (2 icon from above), select design library, then annotation and you will see a set of symbols; It is blocks and if you stop a second with the mouse on the annotation folder you will see that it displays a folder address.
in the library you can create as many folders as you want to insert blocks, annotations, symbols, parts etc.
indicates that they had the shape of blocks. the directory you see is an index of the project library.
better understanding: You can access the blocks by opening the task pane (ctrl+f1), navigating to the project library (the second icon from above), clicking the project library and finally clicking the annotation tab. basketball stars
you did nothing but reiterate exactly what I wrote in post #16
Good afternoon to all!
Following the various interventions I did not find how to create a block where inserting it in the same design, from time to time the text can be changed without all the blocks inserted before being subject to change too.
I'll explain better.
if I in a drawing of the revisions (that do not recalculate the automatic system that from solidworks) and I have the block revision, if by chance I insert the same file block at a distance of days, known that if before there was revision 01, automatically if I varied a size and for so I put the design in revision 02, if I manipulate the file block, everything goes to "02".
I'd like it if it was possible to avoid this.
thank you for collaboration, greeting!
