blue lines around imported bodies
  • Thread starter Thread starter federicomassimi
federicomassimi
Hello.
I noticed that often when I amount a step model, all contours are highlighted with blue lines.
for example here:1708093022476.webpAnd I don't understand how I can eliminate them. Can you help me?
Thank you in advance.
Okay, thank you very much.
and can I easily convert them to solid bodies?
depends on why they are surfaces. the command for conversion is trivial, but if the surfaces are open you must first close. in an object like that in figure could be complicated.
seems to be the result of a rescue as part, with activated the option "external steps", using solidworks.
If so, you might ask who provided you with the file to save the axieme as part with option "all components" and once opened as part start the defeature.
