boats
  • Thread starter Thread starter africagia
africagia
Hello.
I wanted to make a boat with proe wf3. but to make boats you must use the usual features or there are features that facilitate the realization of a boat. with the usual features (extrusions, revolutions, etc.) seems a bit too complex. Am I wrong? Thank you.
Hello.
but how do you do it? I mean, to draw a hull, you need the building plan. Do you have it?
curves and surfaces.
It is clear that you do not realize complex forms with extrusion and revolution.
But if you realize the section curves, the construction plan and what else, the geometry pulls it out.
if you have the isdx module the thing is easier but, even with the basic module you can do.
That's my doubt. How do I draw the hull that has that strange shape?
Meanwhile take a look at this discussionhttp://www.cad3d.it/forum1/showthread.php?t=10265 and try to understand where to start (which applies to all softwares).
then look at this study uses proes for the design of famines:http://www.randit.com/allegati/prorandit/clienti/mpdesign.pdfdo a research about it; with google something is found.
Of course, if you don't have a slight infarination of the subject you'll be very difficult.
but do you want to do so much for your personal taste or is it a real need? What do you normally do?
Marco:smile:
Well, if you start by saying that the hull has that weird shape, we're a little in the reeds. .
I'm joking, I understand that for those who aren't in the problem, it looks kind of weird. the difficult is that the hull has only one symmetry plan that is the diametric one. therefore, each point that identifies a line of famine, has three x,y and z values, which are not equal at any other point.
is not easy to explain online. You should see a building plan and try practically. if you follow this discussion:http://www.cad3d.it/forum1/showthread.php?t=14840We'll see to help you.
cut...
Marco:smile:
in fact rotten as always catches in the sign!
thank you all for the answers. no is not a real requirement. I am a student (in meditation!) and I wanted to improve myself to use proes. As I have a small boat I put the problem.
