bolted connection: asola?
  • Thread starter Thread starter braunfish
braunfish
I have to perform a bolted connection between the lock and the sheet below.
- How can I make a hole in the block and a socket in the sheet?
- I need a m12x35 screw. Why don't you let me use a shorter than 55?
Maybe you could do the socket with the bolted connection! ! ! ! !
create an i-feature asola and the positions in the sheet.
for point 2 maybe select the partially threaded screw, so you are at the minimum limit of screw length
