matteostasim
Good evening,
I have the following problem: in a set I have both vice cl. 8.8 and a2 (inox). since the "number part" that the bolted connection generates only standard and size (e.g. in the case of the dice "uni 5588 - m12"), in the distinct materials I find myself grouped both the nuts m12 in iron and the stainless ones, with the box of the colored materials in yellow and the writing *vari*. if in the separate components of the 3d axieme I could also accept the thing, in the distinct components of the table absolutely not.
I had thought of going to manually add in the dice's iproperties to the "number part" the appendix "a2" or "cl. 8.8" depending on the cases so as to cancel the grouping in separate. but being read-only elements (book elements) does not allow you.
So I was wondering: is there a way to discriminate in separate material and avoid the positions being grouped only according to the "number part"?
