bolts not available
  • Thread starter Thread starter dicifa
dicifa
hi guys....before exposing my problem I wanted to wish good year to all!!! !
...I have this problem:I was planning a freezing plant with inv 2010 and before I sent everything to production I had to show the plant to the final customer. .. fortunately they use inv 2010 therefore, I saved all the project on a stick and went to him.....when we opened the project with his pc, inv did not find all the components inserted by the "content center" (bulbs, washers, dice and bearings)...... is it possible that copying the cat are not copied all the components of the contained center I inserted? Can you tell me what to do?
I tried to do a search in the forum but I couldn't solve the problem.. .
hello and thank you all.... .
Yes.to make the copy of the whole project you must make a pack&go in such a way that he also takes the commercials of the content center.Have you done a pack&go or have you just copied the simple folder with your files? ? ?
I just copied the folder with my files and honestly I don't know how to make the pack&go, indeed, never heard until now....can you tell me how to do it?
Hi... I'm sorry if I interfere... .
to make the pack&go you have to close inventor go to the folder where the general axieme resides to select it and open the atendina with the right button.
you will find the item pack&go....check it and follow the instructions..it is quite simple once you take the hand....
Good job
Thanks legocad, I'll be right back tomorrow and I'll let you know how it went... .
thanks and hello
thanks and hello
in the curtain opening you have a set of options.
leave the spuns on:
1) keeps folder hierarchy
2) including linked files
3) group work groups
4) ignore styles
5) ignore patterns
if you already have some crops you must also go to the area " search for reference files ", click " search now " and wait for you to find more files.
from your client set the project file that you will find included in the folder generated by the pack and go.
make a try before you go to the customer, save you a figion:biggrin:
Bye.
make a try before you go to the customer, save you a figurone
...but don't do it on your computer because it's not worth.. .
If the bolts are on the premises, change computers... if they are on the disconnected server. . .
means that the pack&go gathers everything in one folder, without recreating the starting organization of the folders
the option that groups everything in one folder is: " keeps folder hierarchy " unchecked.
"groups of work " is used to collect data from the whole team running the project (I have never used it).
Bye.
Bye.
You're right. I went to memory without checking. . .:tongue:
