bookcase file transport together
  • Thread starter Thread starter cagliuz
cagliuz
hello to all I have a problem about opening one of a set from one computer to another
I would like to know if there is a faster or automatic method of saving the files of the center directly contained in the axieme folder
I solved by copying the inventor folder from documents and opening the file, on another computer, doing manual search of library components but requires constant updating of the folder and in case of error the axieme does not solve me by sending the program in paranoia obliging me to remake certain processing and parts
Thank you in advance
go to the file together from windows, dx key and in the menu you will find the pack&go that practically relative to the project makes you a folder where it groups all the components and commercial bookstores of your set.
Thanks guys I think you saved me from other hours of work behind a fucking reducer
,other problems when save a file part or together rhymes to save it I appear a window which tells me that the file is not saved in the active project is solved with the pack and go or do I have to do another process? ?
I think you have some basics of inventor.. .
inventor works on projects and qindi every file you make related to a project remains connected to it.
I suggest you read the great guide of autodsk inventor of the pruneri or the guide of inventor 2012 and new techniques.
