boolean operations
  • Thread starter Thread starter ance
ance
Hello
I wanted to know if it is possible to carry out boolean operations on walls, roofs etc.
in autocad architecture there are two types of Boolean operations, those "classes" to be carried out on the solids of autocad and those to be applied on the elements of mass architecture.
these Boolean operations on mass elements:
- Mass Elementunion (sing)
- Masselementsubtract (sing)
- massementintersect (intersection).
for all other objects (walls, suns and more) there are modifiers in the fast selection menu (the dx key), for example:
- for the walls the command "wallbody" (body changer) to add, subtract or replace other objects to this,
- for the suns "weakness",
- for the stairs "stair"....
thank you for the answer, but I hoped that you could subtract or sum any solid to an object
Of course you can. you just have to consider that:
  1. are not called Boolean operations but body modifiers,
  2. you can recall these functions from the right button of the selected object.
