booleane e catia
  • Thread starter Thread starter opua
Hello everyone,
I welcome this discussion not to open another discussion, (maybe for a few steps)
I need to change the polarity of a body, that is, using the possibility of drilling with the drillhole I have to make a body that inside has a "copy as result with link" of the partbody.
This body called drillhole must be negative.
I don't remember how polarity changes in bodies
thanks to all
Sbilf
Maybe I figured out what you're asking, but I'm not sure if you put a presentation or img on what you've done and what you'd like we can help you
attached a catpart (v5r19) with the body3 "copy as result with link" from the partbody inside the same catpart
I want the body3 to become a negative sign to use it in other files in operation assembled at partbody.
Sbilf
you just have to reverse the boolean sign when you do the operazone on the body to which you tie the copied volume.
if you have a negative volume, applying a boolean of subtraction, you will remove the volume (the same for assembly), and instead use the buleaana of sum, the suction is the sum of the volume.
