break a line in multiple points
  • Thread starter Thread starter joe
joe
Good morning to all
I would like to know if you can break a line in multiple points at the same time:
If I want to split it for example in five parts, can I break it at the same time in those four points so as to get five isolated segments?
at the same time not, but you can combine commands _ e _break to get what you need.
with the first insert 4 points on the line that you will need as references to break it.
or faster:
- create points with divide
- cancel the line
- make five new contigue lines.
I had made a lisp to divide polylines into segments, I give it a "external use" and attach it.
by now it will be late, but in the future it could serve someone.
the lisp divides lines, polylinees, 3dpolilinees, arches and splines, breaking into a specified number of single objects of equal length.
for personal use, without control of errors, does not yet work on circles, ellipses and generally on closed spline; for the rest it seems to work.
the previous file is already presenting errors: patience.
