x11start
the variable insunits if left to value 0, allows to import blocks between the various designs keeping the scale of the block itself, the scale with which it was created.
if instead if in the design it is set to a different value (e.g. 4 representing the mm), and a block is created, when the latter is inserted in another design where the variable is placed at a different value.... the block is scaled.
surely the thing is very useful if the lisp were created taking into account, vice versa the thing becomes annoying as the recalled blocks are scaled.
I wonder if it was possible to create a lisp able to place at 0 .... or however to vary all the blocks of a design at the same time, without having to explode and recreate the blocks.
I suppose this is a hidden group code who knows where... .
thanks for the help
thanks for the help
