GunMaker
hi to all, I carried out a buckling analysis on a cross beam and I found that, during post processing, despite there were no errors or warnings during the analysis, almost all the autovalues that are derived from the "results summary" are equal. .
the way I made the fem model is as follows:
1)I created two keypoints at 2000 distance,after I joined them with a line.
2)I recalled the beam element 188 (cubic form).
3)I have created in separate seat a cross section of thickness 2 mm, height 70 mm and width 160 mm.
I then split the various lines that describe the perimeter of the section (as is written in the Help).
Finally I used the command "write from areas (secwrite) " and I selected the area.
4) I imported into the model beams the area via "read sect mesh"
5)I meshato the line created at point 1
6) I checked that the section was correctly imported via the "shape"
7) at this point I have bound the structure (simulating a cart to the loaded ester and a zipper to the unloaded end). Then I loaded the structure with an axial force of 15000 n in correspondence of the cart (on the keypoint).
8)I did first the static analysis (by setting the "calculate prestress effect") after which, once the static analysis has ended, I re-launched a new analysis "eigen buckling" setting in "analysis options" to extract the first 10 autovalues.
the exercise in question is as follows (if it were not clear to describe the problem):
the answer that gave me the program is that of the first image... obviously there is something that doesn't fit... but I just can't understand what I'm wrong. Did anyone ever encounter similar problems? How did you solve them? :frown:
thanks in advance for answers and availability :redface: .
the way I made the fem model is as follows:1)I created two keypoints at 2000 distance,after I joined them with a line.
I then split the various lines that describe the perimeter of the section (as is written in the Help).Finally I used the command "write from areas (secwrite) " and I selected the area.
7) at this point I have bound the structure (simulating a cart to the loaded ester and a zipper to the unloaded end). Then I loaded the structure with an axial force of 15000 n in correspondence of the cart (on the keypoint).8)I did first the static analysis (by setting the "calculate prestress effect") after which, once the static analysis has ended, I re-launched a new analysis "eigen buckling" setting in "analysis options" to extract the first 10 autovalues.
the answer that gave me the program is that of the first image... obviously there is something that doesn't fit... but I just can't understand what I'm wrong. Did anyone ever encounter similar problems? How did you solve them? :frown:thanks in advance for answers and availability :redface: .
