bug fori advance steel
  • Thread starter Thread starter Putrella
Putrella
good morning to all..capita to some users of advance steel that, in case you eliminate a joint, sometimes remain on the beams the fixed holes not editable.. . In short...as if the holes were not a characteristic of the joint but of the beam.. .
Is there a way to update or eliminate this problem?
thanks for the help
holes are an integral part of the bolt. If you delete the bolt and remain the holes, it means they are double.
as for the joint, you delete by selecting an object; If you delete it through his cube, you're not erasing it, but exploding.
thanks iceman....in fact the problem is that... clearing the box first then the elements the holes remain because it is as if I had exploded the joint...
Thank you so much!
